Arcade Filter by Date
10567
6
05-06-2020 06:52 AM
KevinBrown10
Hello,
I wish to utilize the Filter function in Arcade to only return results between 1/1/2019 and 12/31/2019.  I understand the Filter function is  Filter(featurerSet, filter) where filter is an SQL text string.  The features are stored with a Date/Time field.  I am just not understanding the proper SQL commands for working with Date/Time.
Any help or direction to more resources is appreciated.
I tagged you Xander Bakker‌ because I (a non-programmer) have learned much about Arcade following your numerous examples and help to others on GeoNet.
Thanks.
Kevin
Tags (3)
XanderBakker
Esri Esteemed Contributor
Hi k.brown ;
It seems that the expression below works (the same format as you would use in Desktop):
var sql = "LASTUPDATE BETWEEN date '01/01/2019' and date '12/31/2019'";
var fs = Filter($layer, sql);
return Count(fs);
XanderBakker
Hi k.brown ;
return Count(fs);
KevinBrown10
Perfect!  This worked for me.
Thank you very much for your quick response.  As I stated, I do not have much coding experience but following along with your examples is very helpful.
Much appreciated.
KB
XanderBakker
Hi https://community.esri.com/people/k.brown,
I'm glad it worked!
TL2
I am using this same filter() in Pro 3.0 with a service published to Server/Federated 10.9.1.  My arcade expression works fine in Pro, but it fails in Field Maps and Web AppBuilder with the error on the filter()  - Line 4: "Failed to query statistics".  Are there any limitations to this, I wouldn't think so.
My Holidays table is just a table of holidays, querying of the date column.
var t30 = dateadd($feature.initialreport,42,'days')
var t = dateadd($feature.initialreport,0,'days')
//query my date field - dt - on my holidays table
var sqls = "dt BETWEEN @t and @t30";
var fs = count(Filter(FeatureSetbyName($datastore, "SUDOECMS.DBO.Holiday"), sqls))
var dayz = dateadd($feature.initialreport,fs + 42,'days')
return dayz;
nanayawosei
Hi
I am trying to implement a similar query with arcade and sql, but I can not seem to get it to work when I include variables for my dates:
var myDate1  = '01/01/2019'
var myDate2  = '12/31/2019'
var sql = "LASTUPDATE BETWEEN date 'myDate1' and date 'MyDate2'";
return Count(fs);‍‍‍
Thanks ,
Nana
TomNeer
Nana,
You probably figured this out but use the @ symbol in front of your variables to call them inline.
var sql = "LASTUPDATE BETWEEN @myDate1 and @MyDate2";
