Arcade expression - getting Object ID from another table by the common attribute
3080
05-04-2020 02:58 PM
KerryKang
Hello all,
I hope to find way to retrieve the original object ID of the joined layer(a view layer) through Arcade.
Layer 2 is a joined view layer from Layer 1 and Table 1. I need to call the original object ID (Layer 1) inside of Layer 2 in order to pass urls that are created by some sort of combination of the original object IDs.
For example there are 5 records in Layer 1 from object id 1 to 5. But by joining, Layer 2 became to have 10 rows, and the original object IDs are not preserved in the same way.
I was thinking about retrieving the original object ID from Layer 1 by using the common attribute called track ID. Tow layers (Layer 1 and 2 are added in the map).
newValue = Layer1.OID where Layer1.TrackID == Layer2.TrackID
Is it possible to write Arcade like above? I've been using python mostly so not super familiar with Arcade yet.
Here are some challenges -  these are dynamic layer - new records are kept added by survey123, so the filed cannot be pre-calcuated by adding a new column. I should be able to extract the original ID on the fly.
Cheers,
K
KerryKang
I could figure it out
var lookup = $feature.trackID
var temp = FeatureSetByName($map,"map_name")
var newValue = Filter(temp,  'trackID = @lookup')
return Text(newValue.objectid)
Cheers,
K
KerryKang
Cheers,
K
