All point features are lost when publishing a hosted feature service
1168
05-16-2017 01:18 PM
DakeHenderson
All point features are lost when I publish a hosted feature service.  It's a simple feature class in a file gdb, editor tracking enabled.  I can see the features in the preview in the Service Editor.  The schema comes through fine.  No definition query is set, no scale ranges- it's very simple. Any thoughts?
AdrianWelsh
MVP Honored Contributor
Dake,
Can you share the web map with the lost features? Have you been able to publish other feature classes successfully?
KellyGerrow
Esri Alum
It would be really helpful if you could share the data or get into contact with technical support. What field names are you using?
-Kelly
