AGOL JOIN command: do match field data types have to match?
1252
04-13-2023 10:17 AM
JayLarsen
I use the JOIN command quite a bit to add data to ZIP layers.  So, I do a JOIN on the ZIP field.  Does JOIN convert types to match?  E.g. if I JOIN on ZIP that is integer and the other layer ZIP is a string (as it should be) will the JOIN work?
I got this question from a colleague and I simply don't know.  I haven't run into it.
The Living Atlas ZIP layer the ZIP filed as a string, and I usually type mine as string when upload data.
Has anybody done this experiment? Is there a known spec on the JOIN command, e.g. would integer = 2 match a float = 2?
I'd love to see a doc or answer to this, just in case...
Thank You.
David_McRitchie
I gave this a quick test and the field types will need to be the same.
If you have a copy of the layer then I would recommend creating a new field with the matching data type, then use the Field Calculator to transfer the values from the old field.
Esri UK -Technical Support Analyst
David_McRitchie
JayLarsen
Thanks!
I can't believe I was just lucky for all of these years.
