AGOL Hosted Feature Service Won't Create - just spins
692
07-02-2025 10:21 AM
DavidColey
MVP Frequent Contributor
Hello - I have a hosted feature layer that will not "render" itself as available on the overview page.  It just says 'creating service' and nothing is available.  The Data page shows no records, the Visualization page shows no layer, and the Settings page won't come up either.
The ArcGIS Online health check says everything is ok, but it's not.  I can see the layers' rest end point from the services end point:
https://services3.arcgis.com/icrWMv7eBkctFu1f/ArcGIS/rest/services/ParcelHosted/FeatureServer/0
But it won't come up on it's overview page
David
DavidColey
Oh well, problem solved for now I guess.  Normally I overwrite this layer for Open Data nightly using the arcPy sharing module.  I performed an overwrite from Pro 3.5.1 and fortunately it was successful.... and now the layer properties on the overview page, etc are visible.
Perhaps the Service Definition overwrite with the arcPy sharing module had a hiccup, although the script was successful.
