AGOL Data Collaborations - Logs ?
797
02-11-2025 08:00 AM
FelixMcCarthy01
Can anyone tell me where to find the AGOL logs for Data Collaborations?  I have a collaboration from Enterprise Portal to AGOL that is failing on one collaborated data service.  I know there is a log I can view that will let me know which dataset is failing........  just can't find it....
David_McRitchie
Hey Felix
It would be worth checking the Portal for ArcGIS Logs (documentation). Generally most issues are flagged under the Severe level errors.
If you can identify a specific timestamp that collaborations are failing in then this will help filter any noise out of the logs.
In regards to troubleshooting I would also try rebuilding the collaboration, as this is usually the quickest way to resolve issues.
Hope that helps
David
Esri UK -Technical Support Analyst
