Adjust Max/Min Decimals in Cluster Fields in Map Viewer
558
01-12-2026 07:29 AM
Labels (3)
apgis16
I am trying to limit the decimal points in the pop-up but I don't see an option to do so. I first symbolized the point by crash type, and then turned on chart clustering. I want to see the amount of crash types per cluster. Seems like a simple solution but I don't know why I can't find it.
Teresa_Blader
You can do this either in "Field" icon on the side (below the popup icon) - click that field and set the number of decimal points.
Or you can create a new attribute expression and use Arcade Round(fieldname,2) and then select that new attribute expression in the your fields list in the drop down.
Teresa Blader
Olmsted County GIS
GIS Analyst - GIS Solutions
Teresa_Blader
OOPS SORRY! You meant when clustering! 🤓
Teresa Blader
Olmsted County GIS
apgis16
No worries! Weird I don't see a place to adjust it in cluster fields
