Adding zipped up shapefile to arcgisonline
2183
02-29-2012 11:14 AM
AdamTomko
I keep getting this error when i try to add a shapefile with about 650 features "Unable to import this shapefile error" I attached the shapefile has anyone run into this problem or know of any workarounds to fix it. I was able to add it to the my content section of arcgis online. From there I am not sure how to get it added into one of my maps.
MikeMinami
Esri Notable Contributor
Currently loading shapefiles into a web map is not working. We are working to address the problem and hope to have it working again soon.
Mike
SarahMcCabe1
Any Idea when this will be functional?  Those of us who do not have our own server are out of luck as of now.  This thread started
February 29, so it has been out two weeks?
I guess No Service Level Agreement, no service.
by Anonymous User
Not applicable
Hi Sarah,
This should have been fixed shortly after Mike's post, and does currently work as expected. If you're having issues with a particular shapefile you can upload it so we can test, or you can contact Esri Support Services and have an analyst help you troubleshoot the issue.
Andrew
