Adding watermark to webapp.
1628
11-06-2018 12:37 PM
by Anonymous User
Not applicable
So usually the bottom of an app has the source information listed e.g. ESRI,NOAA,USGS etc. Is there a way to add more information to this? I have a client that wants to add the current username and maybe some copyright information. Is this possible to do?
RobertScheitlin__GISP
Matt,
that information is pulled from the map services used in the map and their copyright information. So no unless you have access to change the copyright info for the services you are using.
by Anonymous User
Not applicable
There are two ways to edit this, you can do it in desktop before you publish or by updating the definition of an existing service:
How To: Modify the copyright text of a hosted feature service in ArcGIS Online
