Adding Fields to a Hosted Feature Layer After Performing a Join: Is It Still Doable?
2229
01-04-2024 08:34 PM
JonJones1
Hello everyone,
I have executed a join between two hosted feature layers in ArcGIS Online. However, due to this action, I've encountered an issue: I'm no longer able to add any fields to either of the two hosted feature layers involved in the join.
I'm wondering if there's a specific setting I need to adjust to regain the ability to add fields to my source hosted feature layers, or is this simply not an option anymore. Geez I really hope it’s still an option 😉
LaurenBallantyne
Hi @JonJones1,
When you create a view through a join, the schema is locked on the source feature layers. This is why you're not seeing the option to add a field. Relaxing the scope of this is on our roadmap. We appreciate the question because it gives this feature another bump on the product development board.
JonJones1
Thank you so much for your response! I do have a follow-up question directly related to this, as being unable to update my joined view layers is causing me to constantly make new ones. Would you mind taking a look at this post where I desperately ask for help on how to perform the request mentioned? I spend a few hours each week having to make new joined view layers.
https://community.esri.com/t5/arcgis-online-questions/seeking-a-tech-wizard-can-you-craft-a-short-vi...
kawakawa4
This isn't a complete solution, but something that saves some time with this issue for me:
when you recreate the join view after deleting it (needs to be a permanent delete, not recycle bin) then adding new fields to the feature layer, if you give your new new view exactly the same name as the one you deleted, the map references that view, there's no need to update anything in the map/s.
MappyIan
We have this exact problem.  I found this 'idea' submitted back in 2020 so I don't hold out much hope for it being implemented despite @LaurenBallantyne suggesting it is in the roadmap: https://community.esri.com/t5/arcgis-online-ideas/allow-adding-fields-to-agol-hosted-layer-with/idc-...
Please give the above idea a thumbs up if you also encounter this issue as it really does need addressing.
