Adding aerial imagery as a layer
2418
11-12-2012 07:16 AM
by Anonymous User
Not applicable
Original User: MCline19
I am building a map and I would like to add my own aerial imagery to my map as a layer that can be turned off and on as needed.  Is there anyway to do to this?
Currently, I have my aerial imagery in an ArcGIS server service.  I tried to "Add Layer from Web" and I received an error message stating that my imagery is "not a supported file type and cannot be added".
by Anonymous User
Not applicable
Original User: mikem
You should be able to add your image service. What is the URL to your service?
Mike
by Anonymous User
Not applicable
Using 'Add layer from Web', I specifically tried adding the two following:
http://gisnet2.cstx.gov/CSTX/rest/services/DevServ2/MapServer/40
http://gisnet2.cstx.gov/CSTX/rest/services/DevServ2/MapServer/41
This is the address to the map:  http://gisnet2.cstx.gov/CSTX/rest/services/DevServ2/MapServer
MikeMinami
Esri Notable Contributor
The error is a bit misleading. It's not that you can't add raster imagery, it's that you can't access it directly as an individual layer from a map service.
There are two types of services that most people typically use: map services and feature services. Map services return an image of the data that is drawn on the server and returned to the client as an image. Thus, map services support complex cartographic symbols. Feature services return feature geometry to clients and expect the clients to draw them. In your particular case, by accessing the individual layer of a map service, the service returns the features of the layer, in the same way a feature service does. Since a raster layer has no feature geometry, it won't draw as features.
You need to access the map service as a whole, with all the layers, in order to see the raster data.
Mike
