Hello! I need assistance with adding related table fields to a polygons popup. The source data is below.
Thank you! @JohanLei1
polygon: https://maps2.dcgis.dc.gov/dcgis/rest/services/DCGIS_DATA/Property_and_Land_WebMercator/MapServer/40
related table: https://maps2.dcgis.dc.gov/dcgis/rest/services/DCGIS_DATA/Property_and_Land_WebMercator/MapServer/69
Solved! Go to Solution.
This expression will show each of the surveys' url
var related = FeatureSetByRelationshipName($feature, "DCGIS.SURDOCS");
var output = `${count(related)} survey`;
if (count(related) != 1) output += "s";
for (var rec in related) {
output += `${TextFormatting.NewLine}• ${rec.FILENETLINK}`
return output;. However, I don't think there's currently a way to make each of them clickable
All the attributes from each related record are available to the popup, as shown in this script.
var counter = 1;
var relatedCount = count(related);
var output;
output += `Record ${counter++}`
for (var attribute in rec){
output += `${TextFormatting.NewLine}• ${attribute}: ${rec[attribute]}`
if (counter <= relatedCount) output += `${TextFormatting.NewLine}${TextFormatting.NewLine}`
return output;
With some more work, I was able to get a clickable link for each related survey. This is using the popup content element. Add in an Arcade element and use this script
var output;
if (relatedCount == 0) {
output = `<p>There are no surveys for this property.<\p>`;
} else if (relatedCount == 1) {
var rec = First(related);
output = `There is 1 survey for this property:
<br>  • <a href="${rec.FILENETLINK}">${rec.DOCGUID}</a>`;
} else {
output = `There are ${relatedCount} surveys for this property:`;
output += `<br>  • <a href="${rec.FILENETLINK}">${rec.DOCGUID}</a>`;
return {
type : 'text',
text : output
This expression will show how many surveys from the table have been done at a property.
return output;You can use that expression in the popup like this
Hi @KenBuja , Thank you for the expression. If I am looking to add the one or more attributes from the related table, not simply a count, is there an additional Arcade expression that makes that happen? The related table has an image type field and an image URL. I would like the image type attribute(s) and the image URL(s) to show in the popup - not only accessible in the "related tables" link at the bottom. Thank you!
Hi @KenBuja : Thank you again for the additional expression! This is very promising. I do wonder what are the technical limitations specific to bringing in the full data from related tables. I will implement the expression that you provided and let you know when it works (and accept as solution), and I will let you know if I find out how to make all the link data actual links to the image. Thank you!!!
var counter = 1;
var output;
return output;
var output;
} else {
return {
type : 'text',
text : output
Hi @KenBuja
Can you assist again with a similar expression? FYI I am still on Classic Map if that matters here.
The polygon: https://maps2.dcgis.dc.gov/dcgis/rest/services/DCGIS_DATA/Property_and_Land_WebMercator/MapServer/40
The related table: https://maps2.dcgis.dc.gov/dcgis/rest/services/DCGIS_DATA/Property_and_Land_WebMercator/MapServer/53
The fields from the related table for the popup:
Thank you!
Give this a try:
var rec = First(FeatureSetByRelationshipName($feature, "DCGIS.ITSPE", ['BIDNAME', 'BIDTOTALDUE', 'BIDCOLLECTED', 'BIDBALANCE']));
return `${rec.BIDNAME}
• Total Due: ${Text(rec.BIDTOTALDUE, '$#,###.00')}
• Collected: ${Text(rec.BIDCOLLECTED, '$#,###.00')}
• Balance: ${Text(rec.BIDBALANCE, '$#,###.00')}`
