Add Bing Maps as Layer not Basemap
1126
12-11-2013 04:45 AM
KevinWatt
Can you add Bing Maps to an arcgis.com webmap as a Layer instead of a basemap?  By default Bing shows up as a basemap.  When you switch basemaps using the basemap button, you have no option to go back to Bing as a basemap.  You have to add Bing all over again.  That is why I want to add Bing as a layer so it will persist in my map as an option to turn on/off.
TimWitt
It should be as a layer in your map if you follow these steps? Or does that still cause a problem?
KevinWatt
Hi Tim,
Thank you for your reply.  The link you sent was the process I was using.  It adds Bing as a basemap (bottom layer in TOC), not as a layer that you can turn on and off.  I was hoping someone knew of another way.
