3D web scene popups are missing data. Length limit to web scene popup.
6226
5
06-05-2023 05:22 PM
MarkLysecky
I made a 3D Web Scene and when I click on the points the popups are  missing data sometimes.  The text I am trying to load is the "DAY_TEXT" field.  I loaded the same feature layer into a webmap and all the popups work properly.
I went through about half of the points and all the ones with a length less than 1024 seem to load and the others don't which leads me to believe that there is a limit.
Does anyone know if there is a limit in web scene popups?
The webmap is here
The scene is here
Here are the lengths of text fields based on date
5182229
5248000
5251096
5262509
527426
528160
5293362
5303540
5303540
5303540
5312738
6012160
6021682
6021682
6032624
604957
605757
606825
6072530
6083775
6094964
6102020
611288
2 Solutions
GreteSoosalu
Hi @MarkLysecky
Thanks for drawing out attention to this! I agree, this is seems unexpected. We'll look into having the SceneView behavior in sync with the MapView.
MarkLysecky
Thanks.  In case anyone stumbles across this post.  The scene linked does not show the problem.  I broke the DAY_TEXT field in to DAY_TEXT_1, 2, 3 etc. that only contained 1023 character and then defined the popup to add the text together again.
GreteSoosalu
Hi @MarkLysecky
DevinJacobs_JGI
Just wondering, any progress on this issue? I'm running into something similar with web scenes not displaying popup data of long text fields
MarkLysecky
GreteSoosalu
Hi @DevinJacobs_JGI
We're working on removing this limitation of 1024 characters per text field. But until it is released, the recommended workaround is what @MarkLysecky suggested above.
GreteSoosalu
Hi @MarkLysecky and @DevinJacobs_JGI
we're removing the character limitation for popup fields in the upcoming release of the SDK (version 4.29). If you want to test out this fix before it heads to production, check out the development version of the API, https://js.arcgis.com/next.
Let us know if you are still running into any issues - thanks!
