Web Map routing: Allow us to set geocoder for individual Web Map (rather than whole org)
1143
07-07-2015 09:09 AM
Status: Open
JeffDuMez1
Currently, the default custom geocoder is set on the Organization page, and each web map defaults to that specific geocoder used for all Web Maps in the organization.   BETTER IDEA:   It would be great if each Web Map's address search could be set up with a specific geocoder, rather than having to always use the one set as the default for the whole organization.   Purpose: One web map might be better suited using a 'street address range' geocoder, while another needs to find individual address points (depending on accuracy requirements of the Web Map) or a different geocoding solution.
2 Comments
KellyGerrow
Although this functionality is not available through the map viewer at this time, you can specify specific geocoders for use for search in some of the configurable apps.
ABQOrganization
We need this too!  I would further ask for the ability to pick not just one, but any of the multiple geocoders we have set.  Just like on web apps.
As the other comment says, you can do this for web apps.  However, any geocoders you set up are automatically available from every web map.  So the user is presented with all of them, and there is nothing you can do about it.
