Support sync for field types: esriFieldTypeTimeOnly, esriFieldTypeDateOnly, esriFieldTypeTimestampOffset and esriFieldTypeBigInteger
3272
10
11-18-2024 07:00 AM
Status: Open
MitchellGrafstein
ENH-000172248 - Support sync for field types: esriFieldTypeTimeOnly, esriFieldTypeDateOnly, esriFieldTypeTimestampOffset and esriFieldTypeBigInteger.
In ArcGIS Online (and ArcGIS Enterprise,) sync is not currently supported for new data types:  esriFieldTypeTimeOnly, esriFieldTypeDateOnly, esriFieldTypeTimestampOffset and esriFieldTypeBigInteger
Since sync is not supported, the data cannot be used offline in ArcGIS Field Maps or sent as copies in distributed collaborations. Our users want to take offline areas, make edits in the field, and sync the edits back to the feature services.
@LisaDong , @PindeFu . @SamuelDziel , @EricaWilley , @BrettWeiler , @JakobCutter
10 Comments
RichardHowe
Huge oversight. This shouldn't even need an idea and should be treated as a bug IMO
MitchellGrafstein
@LisaDong - Hope you are doing well.  I am curious if you saw any movement on this.  I do not have access to MyEsri for the Org that this ticket was submitted under, so I cannot check on the status of the ticket or enhancement request.
Thank you.
Sincerely,
Mitchell Grafstein, Horticultural Inspector 1, NYS Dept. of Agriculture & Markets
LisaDong
@MitchellGrafstein Hi Mitchell, long time no chat. I hope you are doing well! I took a look at the enhancement and saw that it's still in review. For any other organizations that need this enhancement, please log a case with Technical Support so that we can attach your case to the enhancement and increase the visibility.
MitchellGrafstein
Thank you, @LisaDong , greatly appreciate the rapid response and information.  Also, thank you again for working with us on this.  I should be able to add my other org tomorrow.
Sincerely,
LisaDong
@MitchellGrafstein Of course, anytime Mitchell!
LeviCecil
This also needs to work in Enterprise. I can't add any time or date field to a Field Maps form. Even the older date/time field.
LisaDong
@LeviCecil Hi Levi, feel free to contact Technical Support to log a case and attach the enhancement to your organization. Side note - there shouldn't be an issue with the Date field. If we are running into an issue with the original Date field, we may be encountering a different issue.
TD1
I consider this a bug. This needs to be fixed ASAP.
Why should I be restricted in the field types I can use on Field Maps.
I use ArcGIS Online and sync is turned off and I still get the same errors.
L77
Our organization doesn't need to track time, we only need to track date so we would like to be able to use the date only field type in offline areas in field maps.
The combined date and time column causes issues with exporting to excel and trying to use pivot tables.
LukeWebb
+1 to this is a bug.
Why do we need to up-vote bug fixes?
