specify which geocoder with ArcGIS Online Find URL parameter
971
06-22-2015 08:41 AM
Status: Closed
MelanieWawryk
You should be able to specify which geocoder to use when using the Find URL parameter for webmaps. You can add in a custom geocoder to a webmap and that works fine but when you use the &find parameter with the URL to the webmap it still uses the world geocoder. It should either use the one that was set up for the webmap to use or allow you to specify the one you want to use in the URL
1 Comment
ScottBall
Status changed to: Closed
