Specify scale on PrintTemplate
1143
08-14-2014 04:38 AM
Status: Closed
NickKouloungis
I would like the ability to specify a map scale for printTemplate outputs in the ArcGIS Javascript API.  I am primarily using the new Finder app deployed on my web server which references an AGOL webmap.  The ability to specify a map scale exists within the default print widget in the Flex API and I would like to see this functionality extended to the Javascript API.
2 Comments
FC_Basson
Esri will need to extend the printTemplate class so that you can set the "mapOptions" parameters.  See this link  http://resources.arcgis.com/en/help/rest/apiref/exportwebmap_spec.html. If you can construct the Web_Map_as_JSON for the print task manually, you can specify the scale.
ScottBall
Status changed to: Closed
