Select Features Tool in Map Viewer
4427
07-31-2024 06:49 AM
Status: Open
JonathanMcD
Seems really simple, but quite strange it's not there (unless you frame a map in an app)
Select features tool, please - then couple with an export to tool would be epic.
3 Comments
RussRoberts
Selection is on our roadmap in Map Viewer. With how selection will work between map selection, table selection, chart selection and more we needed to have a way where things could communicate the selection across these components that would work well with small and large selections.
JonathanMcD
@RussRoberts thank you for the response - appreciate it's not quite as simple in coding reality. (also, please, please, please give us ISO 8601 dates, please) 🙂
RussRoberts
We support those with an update last fall. Using the new timestamp offset field depending on how the time zone is configured in the map view will change the display of them but you can also configure this with arcade as well.
https://www.esri.com/arcgis-blog/products/arcgis-online/mapping/working-with-time-zones-in-map-viewe...
https://www.esri.com/arcgis-blog/products/arcgis-online/mapping/time-is-on-your-side-with-new-field-...
