Save Web Mapping application as a new map
922
11-26-2014 03:50 AM
Status: Closed
AngeloMarino
While it is possible to use "save as" when you are in  the map window, once you have published a web mapping application the only thing you can do with that application is recongifure it.  I would like to use the "save as" feature for one of my applications so I can change one configuration feature and deploy the application.  I have all the colors and text the way I want it and all I want to do is deply the map without the edit button button visibile. I don't want to have to go through all the configuraton again just to change one feature and I don't want to share the editable map to anyone outside my organization.  Essentially a copy and "paste as" feature would be nice for web mapping applications.
Tags (1)
2 Comments
JamieSheehan
Totally agree.... we have a series of Apps with different content (for different regions), but want them all to look the same. If I could simply do a 'save as' I wouldn't have to create a completely new one each time and make each have the same settings.
ScottBall
Status changed to: Closed
