It would be really great if point features in ArcGIS Online could be labeled using "Best Position" position placement type like you can in ArcGIS Pro.
Our engineers, designers, admin, and fielders would greatly benefit from this "Best Position" point labeling AGOL enhancement. Is this in the ESRI Product Plan?
At present, we do not find much convenience or use out of "The nine-grid 'tic-tac-toe' pattern" (AGOL label position of points: Top-left, top-center, top-right, middle-left, center, middle-right, bottom-left, bottom-center, or bottom-right)". When only the top label is visible, such as is default in AGOL, we can easily miss underlying features which can be costly in our telecom industry.
