More placement options for polygon labels
530
02-20-2025 10:39 AM
Status: Open
JenniferBorlick
I would like to see label options other than centered or offset in Map Viewer for polygon layers. Like maybe edge?
I have two layers that are "almost" identical. Zoning parcels and tax parcels. I can't see both labels at the same time, only the one that is on top. If I use offset, for one of them, it sometimes puts the label outside of the polygon, which is problematic for many reasons. I would like to put one or the other along the boundary of the parcel so they don't overlap.
I would also like to be able to re-create our property division maps, which has labeling in specific locations for different layers depending on whether the feature is an outlot, subdivision or CSM.
Thank you for your consideration.
Tags (3)
