Hope the map viewer popup window's size can be re-defined by map creators. Currently the popup can be customized, but the whole popup window size is not adjustable. Sometimes the popups do not need to be that wide, when end users want to see both the attributes in the popup window and the selected feature and around environment in the map, the popup window may block too big part of the map.
