Instant App - Social media share button doesn't work
1298
07-25-2024 05:58 AM
Status: Open
SarahNoakes1
The Instant App Social media share button doesn't work if the web map consists of "too many" layers (so far I have been unable to ascertain what the limit is).
You can add the button to the app, but when the user clicks on it, nothing happens.
It would be a better UX if the builder stopped you adding the share button to an app that is too complex for it to cope with.  It would also be helpful if this limitation was documented.
Sarah
3 Comments
OliverNoah
Hi, Here is Solution to Instant App Social Media Share Button Problem
  1. Simplify the Web Map :-
 Reduce Layers: Kill nonessential layers to make the map simpler.
 Consolidate Layers: Where it makes sense to do so, consolidate similar data into single layers.
  1. Testing:
  Incremental Testing: Start with a very simple map and add one layer at a time to isolate when the share button fails.
  1. User Experience Improvements:
Block 'Add Share Button': Change the app builder not to allow the creation of a share button if the map has too many layers.
User Feedback: Enable the app to tell the user why a share button is not enabled and provide an action item on simplifying the map.
  1. Documentation:
Document the Limitation: Clearly document this limitation in the number of layers in user guides.
Best Practices to Share: How to share a map with fewer layers.
  1. Contact Support:
Reach Out for Help: Reach out for further assistance or report the issue to be reviewed in upcoming enhancements.
 Why Your Social Media Following Matters?
Greater Circulation: The more-engaging Share button will bring an increased following to your social media by providing users with ease of sharing your work.
Engagement: A leaner, more shareable map leads to increased user engagement and more shares, therefore building a larger social media following.
Utilizing a social media followers app helps boost engagement and grow your online presence by ensuring easy and effective content sharing.
By making your web map lean and more user-friendly, you'll be ensuring that your social media share button really does its work in drawing and engaging more followers.
KellyHutchins
@SarahNoakes1 is your map public? If so can you shre it so we can take a look? If not can you tell me more about your map? How many layers? Also if you run your app with the developer tools open are there any errors?
SarahNoakes1
Hi @KellyHutchins,
This is the Instant App: https://cornwallcouncil.maps.arcgis.com/apps/instant/basic/index.html?appid=12089a5be5d44184a838b577...
I think there are about 220 layers at present.  We are trying to convince users that small, subject specific sites would be better, but they are used to having everything in one place.
I haven't noticed any errors.
