Improve Web Map Viewer Performance
752
07-18-2025 02:04 PM
Status: Open
DanLissick
Improve the performance of web map viewer to be the same as Field Maps app.
Below are issues Esri support as described with the new map viewer:
Summary/Documentation:
  • The information we received from internal is that this behavior is expected with 4x (i.e., the Maps SDK for JavaScript). Complex polyline and polygon layers are generalized to improve query time. This is different than 3x which loads these geometries differently.
  • We also see layers be generalized/optimized by default when they have more than 400,000 vertices to protect the organization's datastore. This is mentioned in our documentation here:
  • From the example layer with which we've reproduced the behavior with in-house, we observed that it's a complex polyline layer that by default, has been optimized by the software upon publishing.
  • In general, we have the mantra of no more than one vertex per pixel at any particular scale, meaning that data is being generalized dynamically when being viewed. This isn't bluntly stated in our documentation anywhere, but this topic is touched on in the video resource linked below. Note the discussion at about 24:50 minutes in.
  • This blog also touches on a similar topic of discussion:
  • My colleague that I was working with has mentioned to internal that the difference between 3x and 4x loading should be documented somewhere - but they would also encourage you to leave feedback directly on our documentation using the 'feedback on this topic?' option on the Map Viewer documentation page as well.
  • Additionally, the reason that ArcGIS Field Maps and our other Mobile applications do not display the same behavior is because our mobile apps are not built on the same code base - JavaScript is used for web clients while our mobile apps use a product called ArcGIS Runtime or ArcGIS Maps SDKs for Native Apps | Documentation | Esri Developer.
  • The existing Enhancement requesting an improvement in how Map Viewer renders features upon zoom in is ENH-000163087, and has been attached to this case.
I've also provided the feedback you passed along to me in regards to this change and inquired regarding if escalating an Enhancement is possible.
Unfortunately there isn't a set process of escalating an Enhancement in the same way that bugs can be escalated - Our bug escalation documentation page states this directly. However some indirect methods of escalating it would include creating a post on our ArcGIS Ideas forum, which can bring additional views and attention to the issue as our development team does browse the ArcGIS Ideas forum. If you do end up doing this, if you can provide me with the link to the Ideas Page, I can directly attach it to the Enhancement to route other users that create cases for this issue to the same enhancement number.
1 Comment
RussRoberts
If you can share the map that is showing the issue we can take a look. You can create a group and invite russell_jsapi into it with the map and layers and we will look into.
