Heat maps in map viewer by using Arcade field
777
04-30-2024 10:14 AM
Status: Open
JasonXiao
Arcade expressions currently are not supported for Heat Maps.
To use Arcade expression with the Heat Map symbology style on ArcGIS Online.
So, I do not need to add a permanent field within the dataset.
1 Comment
RussRoberts
Heatmap is using feature density with kernel proximity method which does not leverage a field.
https://developers.arcgis.com/javascript/latest/api-reference/esri-renderers-HeatmapRenderer.html
