ESRI Basemaps need a print resolution option
3860
09-21-2017 05:41 PM
Status: Open
deleted-user-yMSQSHvui0e5
ESRI Basemaps are great, but when they're used in a map layout designed for print the resolution is simply not sufficient. It would be great if we had the option of requesting high resolution map tiles (>200 ppi) when exporting a document to PDF.
5 Comments
KoryKramer
There is a technical article about this FAQ: Is it possible to improve the resolution of a basemap from ArcGIS Online?  and it links to some other articles as well.
JoshuaBixby
If anything, the referenced technical article only reinforces this idea.  Firstly, it isn't possible to adjust the resolution so proposing it is possible is a request to change the behavior of the software.  Secondly, use a Data Appliance for ArcGIS to get better print quality is an absurd suggestion for most customers.
KoryKramer
Yes, it's clear that it isn't possible, and the Idea is valid which is why it is marked as Reviewed and open to voting.  The reference to the article was because it provides some explanation like "Most cached web map services such as those available from ArcGIS Online are designed for viewing on the screen" and "The basemaps are provided as services, thus such behavior is expected."  Maybe it isn't necessary here, but I usually try to link to documentation, technical articles, other sites, or show screenshots that provide additional context to an idea rather than nothing.
AZendel
Have you tried their vector base maps? I just tried one in a PDF export and the output looked really nice. And you can adjust the colors/styles/fonts, though I'm not sure how to bring a custom vector base map into Pro.
KeithAddison1
If you export from the data frame it doesn't appear to reduce the resolution, not that that's a great solution.  Does Pro have this same behavior?
