Enable scale based display filters by attribute in map viewer from Arcgis Online
389
03-15-2026 11:36 PM
Status: Open
beheer_nf
As of now scale based display filters can be authored in Arcgis Pro.
For our organization it would be very usefull to be able to do this in Arcgis Online too.
2 Comments
RussRoberts
This is on our roadmap to add support for authoring/editing scale and manual based display filters. If you can give your workflow/use case for this would be helpful as we work on this feature.
beheer_nf
I have a layer containing permit applications. Applicants can draw these on the map themselves (if it does not involve just a single address). E.g. in case of an event in the open field or an activity that extends across multiple addresses or a road. Sometimes however, they include the entire area of ​​our municipality (e.g. for an outdoor activity containing a large area). This overlaps the smaller areas, which makes the layer less usable for smaller areas. I would like to exclude the large areas on smaller zoom levels.
The objects on the map could for instance be linked to different zoom levels based on the shape_area attribute.
I have solved this for now by adding (and grouping) several duplicates of the permits layer using filters.
