Enable/Disable Pop Ups at Group Level
597
04-29-2025 02:01 PM
Status: Open
PeterKnoop
MVP Regular Contributor
I would like to be able to enable/disable pop ups for all of the layers in a group at once in Map Viewer.
An example use case for this is when we have a group of GPS track point layers as part of map, as well as other data layers. There might be anywhere from a few to dozens of GPS track point layers in a group layer in the map.
Typically the GPS track log layers are present on the map to provide visual context, showing previous tracks through the area. In this case, when a user is clicking on the map, pop ups for the track log layers are disabled, so the don't obscure the relevant pop ups from other layers.
Sometimes, however, we do want to be able to access the popups for individual track points. For example, when planning a trip to the area, we might want to compare timestamps on points to see how long it took to travel in/out on a one-way portion of the track. It would be helpful in such cases to be able to quickly toggle on the pop ups for the group of GPS layers in the Web Map, explore the GPS track point data, and then toggle off the pop ups for the group again, rather than having to toggle on/off pop ups for individual layers in the group.
