A key resource for achieving the goal of organizational branding, quality, and consistency in map authoring and publishing is a coordinated set of map symbols. An organization that is administering an ArcGIS Online subscription should be able to post its own standard marker symbol galleries for the use of its web map authors. The current method of adding custom images one-by-one via a URL for each one is much too awkward and a highly inefficient way for an organization to employ its own custom symbology.
Using ArcGIS Desktop, I've created a custom style for a complex set of point markers. When I publish the MXD as a map service (share as service), no warning or error messages are generated and the resulting map service does not contain the custom symbology. I've tried using both PNG and EMF images as the source for the marker symbols. I also tracked down a hidden tool that converts a desktop ".style" file to a ".serverstyle" file and copied the ".serverstyle" file into the proper location on the ArcGIS server and then re-started ArcGIS server but the custom symbology still doesn't show up. Seems to me that there should be a standard and simple workflow to accomplish this type of task!?
Just trying to give this idea a bump. I still think this is crucial and is a big deficit in ArcGIS Online.
There should be an interface where users can create a more custom icon, using multiple 'layers' just as exists in Pro or ArcMap. These icons could then be saved and used across other layers and maps.
Yes, I'd like to be able to add styles to server and portal without having to go through this:
