Create a method to swap user license type between two named users
3181
17
05-19-2024 06:17 PM
Status: In Product Plan
RTPL_AU
Currently, if you want to swap the user license type between two users, you need a third unallocated license to play musical chairs with, or to delete>recreate one of the users.
In a small organisation where they typically do not have spare licenses, we have come across situations where due to staff job description changes, they need to swap the user license type between two people. The only way to do that without a spare license, is to delete one user, allocate their old license to the other person and then recreate the user and add them to various groups etc. This seems very inefficient.
Esri should create a way to select two users and swap their user license type.
I am ware that in some cases, primarily where a Creator type is involved, it is a non-trivial task, but Esri should be able to work out how to transfer ownership of assets in the process. DM me if you want me to help the dev team work it out.
17 Comments
henry8653jDawid
To implement a method for swapping the license type between two named users, you can create a function that takes the usernames and their current license types as input parameters. The method should first validate that both users exist and are eligible for the swap. It should then check if the license types are swappable Chairs, ensuring that any specific conditions or restrictions related to each license type are respected.
ChelseaRozek
I'm worried about the many administrative hassles that moving to named user licenses from concurrent licensing will create, this being one of them. We won't be able to afford having unused licenses sitting around for this sort of situation. I can picture this happening to someone who needs to bump up to a Pro Advanced license with Professional Plus for one project, but there are no more Professional/Standard licenses available for the existing Professional Plus to be bumped down to. Like you said, it would be nice if they could just swap in place.
Koen
by Esri Contributor
Hi All,
ENH-000168099
Request for method of swapping user type license between two users without the requirement of an additional unallocated license or deleting an existing user.
Latest update: "This is fixed and will be available with the next ArcGIS Online update - administrators will be able to run the "Transfer member" workflow to transfer licenses, user types and roles between existing users in the organization."
Feel free to create a ticket with Technical Support if you'd like to be attached to the enhancement: Contact Esri Technical Support
Thanks again for writing up this idea!
-Koen
NairiSevajian
NairiSevajian
This Idea was implemented at the October 2025 release of ArcGIS Online. Administrators can now use a single workflow to transfer a member’s user type, role, content, groups, add-on licenses, settings, and member categories to another existing member.
RTPL_AU
@NairiSevajian
I've not had a reason to test this yet but have a question.
If you don't have a free user type can you still do this workflow?  Say you want to swap a Field Worker and Viewer.
From what I see you can transfer the Field Worker user role etc to the other user but does Esri allow you to complete the workflow then downgrade the source user to the lower license type, or do you still need an extra license floating around to be able to do this?
FlorianSteiner
@NairiSevajian @RTPL_AU The implemented solution seems to be a different workflow compared to the original idea. There still needs to be a "spare" user type to be able to swap the roles between two users.
Here in my example, you can see that there are no free user types left and therefore the list of user types is empty for the left user, meaning I cannot use this workflow, to swap the user types between two users.
By the way: Another solution for this problem would be:
ChelseaRozek
@FlorianSteiner Thanks for the explanation, I didn't understand the nuance of the new functionality. It looks like a simple one-way transfer vs. we wanted a two-way transfer, a true swap. If only it realized the right's user type was about to be freed up...
I've upvoted both ideas about disabled users freeing up a license. That would solve so many issues...
DavidWitt
@FlorianSteiner @ChelseaRozek @NairiSevajian The two way transfer/swap is exactly what I'm looking to do. Hopefully ESRI will be able to implement this.
NairiSevajian
@FlorianSteiner @ChelseaRozek @DavidWitt
Hello everyone,
The intent of this feature is to allow you to swap licenses even when no spare user type is available. Thanks for your feedback-- we have logged it as a bug to be fixed. Please see the information here, and you may contact Technical Support to be attached to the defect.
Best,
Nairi
