Control the Identify Tolerance in AGOL Templates
1028
10-31-2014 09:41 AM
Status: Closed
DarylMasten
I would like to be able to control the identify tolerance on at least some of the AGOL application templates.  When I create a map in AGOL and then share it through an application template sometimes the identify tolerance is too small and it can be hard to select points on a smart phone or other small screens.  If I could adjust the identify tolerance I could correct this issue and be able to use the AGOL application instead of downloading it and running it on my own server.
2 Comments
MaryLindsey
I'd love the ability to control the polygon identify tolerance in AGOL maps so that I could keep nearby polygons from being selected and then offered in the pop-up as "1 of 3", for example.
ScottBall
Status changed to: Closed
