Alphabetize domain values
1774
11-14-2023 12:32 PM
Status: Open
Laura
by MVP Regular Contributor
I have a long list of values in my domain and it would be extremely helpful if I could click a button to alphabetize rather than moving each row individually.
5 Comments
RobertBorchert
You may need to sort them in the Pro or ArcMap project from which the service was created.
one way you can do it is to run Domain to Table. Sort your values and do Table to Domain
Laura
This particular layer is tied to a solution so it was not created in Pro
HollyTorpey_LSA
This functionality is sorely needed. We have lots of field data collection templates with very long lists of species. We get asked to add new species now and then and getting them into the right order is painful. I know I could sort them in Pro as @RobertBorchert mentioned above, but often the feature services are in active use in Field Maps and I can't overwrite them. Even if I could, having to open Pro, add them to a project, export them to a GDB, run Sort Coded Value Domain, and then re-publish them is much more onerous than it should be. And what about smaller organizations that are online only? I know many small nonprofits that use this model and would be out of luck. There really should just be a simple sort button. I look for it with great hope after every update.
JeffreySchmidt3000
I would really like to see more domain management options within the data section of a hosted service.  We have 100+ evolving options similar to that described in other comments.  I am looking into field maps designer to see if the form list options there offer anything comparable.  Seems like this could be wrapped into experience builder editor widget as well and handled in arcade.   Most popular choices at the top, most recent choices at the top, alphabetical, things like that could make life easier.
TylerL
I would love to see this happen.
