Saving Developer App issues
3402
08-06-2013 11:57 AM
BrianFlood
there may be some bugs when saving an Application on developers.arcgis.com
1) If you click "Update Application" from the "Application Info" tab, the desc and tags are saved.
2) Once you move to the RedirectUrls tab and add a url, it will save but clear out the desc/tags.
3) Going back to resave the desc/tags then clears out the redirectUrls
cheers
brian
BrianFlood
does anyone else see this issue? or am I doing something wrong?
thanks
brian
PatrickArlt1
I checked this out and can confirm that it looks like your description is deleted upon adding a redirect.
The good news is this doesn't happen on our latest internal build that we are working on right now so it should be fixed soon.
