Custom labeling annotation on web map
3435
02-01-2016 10:13 AM
JieCai
I have a problem to display the calculated property value in javascript api label object. If anybody knows how to solve this issue, could you share your idea? Thanks!
Here is code:
// create a renderer for the FNP layer to override default symbology
            var FNPColor = new Color("#666");
            var FNPColor = new Color("#FF0000");
            var FNPLine = new SimpleLineSymbol("solid", FNPColor, 1.5);
            var FNPSymbol = new SimpleFillSymbol("solid", FNPLine, null);
            var FNPRenderer = new SimpleRenderer(FNPSymbol);
var FNPlayer = new FeatureLayer("https://oursite/webgis/rest/services/Cooperators/cooperatorboundaryandpond/FeatureServer/1", {
                mode: FeatureLayer.MODE_SELECTION,
                outFields: ["*"],
// create a text symbol to define the style of labels
            var FNPLabel = new TextSymbol().setColor(FNPColor);
            FNPLabel.font.setSize("8pt");
            FNPLabel.font.setFamily("arial");
            var json = {
                "labelExpressionInfo": [{ "value": "{Name}" },{"Value"}:calculateAcreageFNP}] // Here is the value need be displayed in the label
                "labelPlacement": "above-right"
            var labelClass = new LabelClass(json);
            labelClass.symbol = FNPLabel; // symbol also can be set in LabelClass' json
            FNPlayer.setLabelingInfo([labelClass]);
function calculateAcreageFNP(value) {
                var sqft = geometryEngine.geodesicArea(value.geometry, "square-feet");
                console.log(sqft);
                var squarefeet = number.format(sqft, { places: 1 });
                var acres = number.format(sqft / 43560, { places: 2 });
                return "Acres :" + acres ;
