arcgis online vector tile service in Leaflet map
2848
04-10-2018 06:25 AM
by Anonymous User
Not applicable
Greetings, I am trying to add an arcgis online served vector tiles service to a Leaflet map. I am using ( https://github.com/Leaflet/Leaflet.VectorGrid ) to add the vector tiles to a Leaflet v1.3.1 map application.
I am able to add ESRI layers into the Leaflet map using the following simplified code:
    var esriTilesUrl = "https://basemaps.arcgis.com/v1/arcgis/rest/services/World_Basemap/VectorTileServer/tile/{z}/{y}/{x}.pbf";
    var esriTilesPbfLayer = L.vectorGrid.protobuf(esriTilesUrl);
    esriTilesPbfLayer.addTo(map);
However, when I try to add my arcgis online vector tiles to the leaflet map using the same code
    var esriTilesUrl =  "https://tiles.arcgis.com/tiles/l4TwMwwoiuEVRPw9/arcgis/rest/services/CaryHouseHolds/VectorTileServer...{z}/{y}/{x}.pbf";
I get the following error:
GET https://tiles.arcgis.com/tiles/l4TwMwwoiuEVRPw9/arcgis/rest/services/CaryHouseHolds/VectorTileServer... 404 ()
What is the correct url to use to consume arcgis online vector tiles?
Thanks, Tyler
yoannjaffrain
Hi Tyler ! I am also trying to add a custom Basemap (which seems to be a vector tile service since the url is https://basemaps.arcgis.com/arcgis/rest/services/World_Basemap_v2/VectorTileServer )
I can't make it work with leaflet.......
What was your solution?
yoannjaffrain
I realize now that this URL cannot be correct because it doesn't take into account my customization.
So my question would : how do you display your ESRI custom basemap with leaflet ? (should use the id ?, ... ?)
Thanks !!!
