ArcGis Online address related pop-up
4181
11-24-2015 12:09 PM
MariaMalpica
Dear all, I am a new user of ArcGIS online. I need to build a map that allows to see the name of the inspector in charge of the area. So far I succeeded in creation a map that shows the boundaries of the neighborhoods and a pop-up (very basic) that shows the information required. I would like to know if there is a way to show the same pop-up (for the corresponding area) when I use the address locator. Example: If I type the address of my house I would like to see (right away) a pop-up showing the name of the inspector that I should contact. Any idea will be welcome, Thanks! 🙂
DavidCrosby
How about using your web map but configuring the Information Lookup hosted application in ArcGIS Online?  This should allow you to accomplish what you want.
http://www.arcgis.com/home/item.html?id=54da82ed8d264bbbb7f9087df8c947c3
Here is a sample implementation.
Information Lookup
DavidCrosby
Information Lookup
MariaMalpica
Thank you so much for helping me
