Add default values to attribute fields
2864
03-20-2014 04:40 PM
JoseSanchez
Hi all
Is there a way to customize the attributes from the editorWidget for a new point or line in a way that I can populate the value of a field Municipality searching in the  municipalities polygon layer the municipality code where the point or line are created, and save it in the Municipality field for the new point or line feature.
The general question is to know if I can add source code an ArcGIS Online Web Application.
thanks
