I've had a longstanding need to visualize, query, and filter features using values from a related table, and came up with the following solution, which works great for my use case.
Note: You can also use joined hosted feature layer views to symbolize by related records, but these have some limitations, as listed in the documentation. But if a joined view works for your use case, it's an easier option.
The use case involves managing stormwater catch basin inspection and cleaning (I've simplified the workflow for purposes of this post). The customer wanted field workers to be able to open Collector and quickly see basins that need attention or haven't been inspected/cleaned in over a year, and provide that same information in a dashboard.
It's easy to set up:
Details on each step above:
from arcgis import GIS
from arcgis.features import FeatureLayer
import pandas as pd
from arcgis.features import SpatialDataFrame
from datetime import datetime, timedelta
import time
gis = GIS(f"https://someorg.maps.arcgis.com", 'someuser', 'somepass')
def update_basins():
one_day = datetime.today() - timedelta(days=1)
string_day = one_day.strftime('%Y-%m-%d %H:%M:%S')
where_query = f"DateInspected >= DATE '{string_day}'"
# get catch basin features
catch_basins = gis.content.get('21343f6579b74cf212576e5614db8866')
catch_basins_lyr = catch_basins.layers[0]
catch_basins_sdf = SpatialDataFrame.from_layer(catch_basins_lyr)
catch_basins_fset = catch_basins_lyr.query()
catch_basins_features = catch_basins_fset.features
# get cleanings records
cleanings_url = 'https://services9.arcgis.com/iERASXD4kaw1L6en/arcgis/rest/services/this_is_an_example/FeatureServer/1'
cleanings_lyr = FeatureLayer(cleanings_url)
cleanings_sdf = SpatialDataFrame.from_layer(cleanings_lyr)
cleanings_fset = cleanings_lyr.query(where=where_query, out_fields='DateInspected, FacilityID, Status')
cleanings_features = cleanings_fset.features
# sort by clreaning date and drop all but most recent
cleanings_df = cleanings_sdf.sort_values('DateInspected', ascending=False)
cleanings_df = df.drop_duplicates(subset="FacilityID")
# find overlapping rows between catch basins and cleanings
overlap_rows = pd.merge(left = catch_basins_sdf, right = df, how='inner', on = 'FacilityID')
def update(basins, cleanings):
for FacilityID in overlap_rows['FacilityID']:
try:
basin_feature = [f for f in basins if f.attributes['FacilityID'] == FacilityID][0]
basin_feature.attributes['LastCleaning'] = cleanings.attributes['DateInspected']
basin_feature.attributes['Status'] = cleanings.attributes['Status']
catch_basins_lyr.edit_features(updates=[basin_feature])
print(f"Updated {basin_feature.attributes['FacilityID']} status to {basin_feature.attributes['Status']}", flush=True)
except Exception as e:
print(f"Could not update {FacilityID}. Exception: {e}")
continue
update(catch_basins_features, cleanings_features)
while True:
update_basins()
time.sleep(60)
var present = Now()
var last_cleaning = $feature.LastCleaning
var cleaning_age = DateDiff(present, last_cleaning, 'years');
If (cleaning_age < 1 && $feature.Status == 'CleaningComplete') {
return "Current"
} else if ($feature.Status == 'NeedsAttention') {
return "Needs Attention"
} else if (cleaning_age > 1) {
return "Expired"
} else if (IsEmpty($feature.Status)) {
return "Record missing or incomplete"
I hope this is helpful to someone. Feel free to offer suggestions or ask questions.
