usage restriction truble
993
09-13-2010 08:13 AM
lorenzoperone
I'm working with Arcgis 9.3 SP3 and the Network analysist extension.
I've a nework street in wich I've to calculate the shortest path from two points (near start/end of some bridges) using the bridge and in case of bridge fall.
When I've build the network dataset I've done an attribute named "interruzioni" (usage restriction) that is based on the field "attivo" (integer: 0 road/bridge inactive, 1 road/bridge active) then in the evaluators I've set Type: field, value <expression>, in the expression I've put this:
Attivo = True
If attivo = 0 Then
Attivo = False
Else
Attivo = True
End if
and in Value= Attivo
When I solve the route the value in the "attivo" field don't make any difference. If I set the field "attivo" in all the record to 0 or 1 the results of the rout are the same, nothing change.
I'm a bit perplexed.
Thanks for suggestions.
lorenzo
lorenzoperone
I've tried, using the vb syntax that you suggets me,
but when I change the value of a network arc record from 1 to 0
don't change noting, the route generated by the solve is the same.
I made some screenshot to describe my settings:
http://www.dropbox.com/gallery/4255917/1/network_analyst?h=d70f9c
Thanks a lot.
Lorenzo
lorenzoperone
It works now!
Thanks a lot.
Bye
Lorenzo
