Two system junctions at one intersection with same elevation
4501
10
12-14-2022 01:01 PM
KisakyeM
I built a network dataset and noticed that I have some unreachable areas. On further investigation, I noticed that the areas that are unreachable are coming off of T intersections with two junctions. The intersection has three streets connected to it and I would expect there to be only one junction but there are two junctions. All the streets are at grade, they are properly connected (no dangles or under shoots) and there are no restrictions that would prevent travel. All the data is singlepart and there are no duplicates. These are system junctions generated during the building of the network dataset. What would cause the system to create two junctions at one intersection? @JaySandhu
melisahansen
@JaySandhu we have not created the network in Pro to see if we continue having this issue. The network was originally created in Map, and we have been maintaining it in Pro. The issue is that when these duplicate junctions occur, we cannot edit them in Pro. Can junctions no longer be edited in a network in Pro?
