To repo this case:
1. Build a random feature set with more than 300 points in Pro
2. Publish it into Enterprise
3. Run the following code with the url of the published feature
4. You will see the error message
If the number of points is less than 300, the code should work.
Here is my code:
from arcgis.gis import GIS
from arcgis.features import FeatureLayer, Feature, FeatureSet, FeatureCollection, use_proximity
username=''
password=''
gis = GIS('', username, password, verify_cert=False, set_active=True)
import arcgis.network as network
origins=FeatureLayer('')
destinations=FeatureLayer('')
result1 = network.analysis.generate_origin_destination_cost_matrix(origins=origins, destinations=destinations, gis=gis)
Here is the error message:
Exception Traceback (most recent call last)
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\geoprocessing\_support.py in _analysis_job_results(gptool, task_url, job_info, job_id)
304 try:
--> 305 param_result = gptool._con.get(
306 result_url, params, token=gptool._token
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\_impl\_con\_connection.py in get(self, path, params, **kwargs)
870 return resp
--> 871 return self._handle_response(
872 resp,
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\_impl\_con\_connection.py in _handle_response(self, resp, file_name, out_path, try_json, force_bytes, ignore_error_key)
1007 errorcode = data["error"]["code"] if "code" in data["error"] else 0
-> 1008 self._handle_json_error(data["error"], errorcode)
1009 return data
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\_impl\_con\_connection.py in _handle_json_error(self, error, errorcode)
1030 errormessage = errormessage + "\n(Error Code: " + str(errorcode) + ")"
-> 1031 raise Exception(errormessage)
1032
Exception: Error getting result parameter
(Error Code: 500)
During handling of the above exception, another exception occurred:
~\AppData\Local\Temp\ipykernel_15924\8243387.py in <cell line: 5>()
3 origins=FeatureLayer('https://arcgis.reyesholdings.com/server/rest/services/Hosted/test_OD/FeatureServer/0')
4 destinations=FeatureLayer('https://arcgis.reyesholdings.com/server/rest/services/Hosted/test_OD/FeatureServer/0')
----> 5 result1 = network.analysis.generate_origin_destination_cost_matrix(origins=origins, destinations=destinations,
6 gis=gis)
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\network\_od.py in generate_origin_destination_cost_matrix(origins, destinations, travel_mode, time_units, distance_units, analysis_region, number_of_destinations_to_find, cutoff, time_of_day, time_zone_for_time_of_day, point_barriers, line_barriers, polygon_barriers, uturn_at_junctions, use_hierarchy, restrictions, attribute_parameter_values, impedance, origin_destination_line_shape, save_output_network_analysis_layer, overrides, time_impedance, distance_impedance, output_format, gis, future)
945 if future:
946 return job
--> 947 return job.result()
948
949
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\geoprocessing\_job.py in result(self)
234 elif self._is_ortho:
235 return self._process_ortho(self._future.result())
--> 236 return self._future.result()
237
238 def _process_ortho(self, result):
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\concurrent\futures\_base.py in result(self, timeout)
444 raise CancelledError()
445 elif self._state == FINISHED:
--> 446 return self.__get_result()
447 else:
448 raise TimeoutError()
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\concurrent\futures\_base.py in __get_result(self)
389 if self._exception:
390 try:
--> 391 raise self._exception
392 finally:
393 # Break a reference cycle with the exception in self._exception
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\concurrent\futures\thread.py in run(self)
56
57 try:
---> 58 result = self.fn(*self.args, **self.kwargs)
59 except BaseException as exc:
60 self.future.set_exception(exc)
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\geoprocessing\_support.py in _future_op(gptool, task_url, job_info, job_id, param_db, return_values, return_messages)
321
322 job_info = _analysis_job_status(gptool, task_url, job_info)
--> 323 resp = _analysis_job_results(gptool, task_url, job_info, job_id)
324
325 # ---------------------async-out---------------------#
307 )
308 except:
--> 309 param_result = gptool._con.get(result_url, params)
310
311 job_value = param_result.get("value")
869 if return_raw_response:
870 return resp
872 resp,
873 file_name,
1006 return data
1009 return data
1010 else:
1029
1032
1033 def post_multipart(
(Error Code: 500)
Hey Junzhe,
Good to hear from you!
Quick question about the failure you ran into, I think you are using ArcGIS Python API with your ArcGIS Enterprise? One thing you could try is to increase the heap size of the OD Cost Matrix GPServer service and see whether it works for your. Here is the documentation.
If it doesn't work, let me know and I can provide some other suggestions.
Also, what is the version of ArcGIS Python API you are using?
Max
Hi Max,
Hope everything went well.
Thanks for reaching out. I increased the heap size and it works !!
Btw, I have one question for this class (ODCostMatrixLayer)
What is the URL in class arcgis.network.ODCostMatrixLayer(url, gis=None)¶ for?
Thanks.
Hey Junzhe,
Great to know it works! The url in the class, is used to provide a url to the synchronous OD Cost Matrix service on the federated server of the portal.
Max
Hey Junzhe,
One other thing worth trying, could you enable logging to debug level so we can get more details?
import logging
root = logging.getLogger()
root.setLevel(logging.DEBUG)
handler = logging.StreamHandler(sys.stdout)
handler.setLevel(logging.DEBUG)
root.addHandler(handler)
And please post the results of that so we can get more details about why the POST request failed.
@MaxZeng Hi Max, sorry for bothering you.
How can I specify 'Name' for the origins and destinations feature set?
The help link https://developers.arcgis.com/python/api-reference/arcgis.network.analysis.html#generate-origin-dest...
said "The name can be an unique identifier for the origin."
Does it mean to append a new attribute into the feature set?
Hey @JunzheZhang ,
Depending on where your feature set is originally from, there are different ways to do it, if your feature set is coming from feature service, then it might be easiest to just add to the service itself. Otherwise, you can get the feature set, convert to dict, add "Name" in "attributes" for each record, and then convert that back to feature set.
The syntax example in the rest API doc might be more clear, it shows feature set with that Name attribute for each record.
@MaxZeng Sorry for bothering you again.
The network analysis tools kept reporting this error. Then, I restarted the NA servers.
However, it reported this error. Do you know how to handle it? Thanks.
@JunzheZhang , ArcGIS Pro uses geoprocessing service, so the failure has nothing to do with not able to restart your NAServer service. You can go to server log and see whether that job ID shows you any message. You could also construct the job url and look at the messages. URL will be something like https://<gpservice-url>/FindRoutes/jobs/[jobID]
If your NetworkAnalysis geoprocessing service is not Info level message, change to Info level message and rerun the analysis, that will have more log messages when you look at the job using that url above.
For the NAServer issue, not sure what is going on. Since the service was fine but have issue after restarting, not sure whether it is data access issue or something like that. See whether the server logs show more.
