Split route with the stops used
1448
11-30-2010 04:39 AM
JosePelayo_Silva
Hello.
Is there a way to split a route line calculated in Network Analyst (i'm using ArcGIS 9.3) with its points? One could have the distance information in the stops layer, but the line segment is just one for each route. What I would like to have is a polyline broken in every stop I've used.
JaySandhu
You could use the GP tool, "Split Line At Point" tool to split the route at the stops after the fact.
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Split_Line_At_Point/00170000003w000000...
Jay Sandhu
