Service area based on linear (polyline) facilities
1181
03-29-2021 07:47 AM
MiguelPadeiro
Hi there,
I am trying to determine a service area around an urban cycle network. More precisely, I would like to create a road network-based buffer around the cycle paths. I am using Network Analyst in ArcGIS Pro 2.6.0.
While it is easy to use this feature with point locations (for example: bikesharing stations), I can't figure out how to use it when the facilities are lines.
Maybe the solution is somewhere in this forum, however I did not find it.
Thanks in advance,
Best regards
JaySandhu
The service area solver (drive time polygons) start from a point location. If you want to do it for a line, then turn it into a series of points, especially  at the junctions of those lines with other lines. Then load all the points as facilities and choose the merge the output polygon option so that a combined polygon is returned.
Jay Sandhu
