Point elevation for snapping 2.5D networks
2095
09-19-2013 06:23 AM
TobiasLitherland1
Hi!
I've got a 2.5D indoor network for an area without any proper Z data. Therefore, the network (covering several floors) uses ordinal elevation values from 0 to 9. The service is being used for simple routing problems from A to B.
My problem is how the routing locations snap to the network. I can't seem to find out how to assign a point to a specific floor (ordinal elevation value) so it snaps to the correct portion of the network. Any tips or workarounds?
Tobias
RobertGarrity
Hi Tobias,
You could use the query builder. See the section entitled "Snapping environment with Build Query" in the following help topic:
http://resources.arcgis.com/en/help/main/10.2/#/What_are_network_analysis_objects/00470000003n000000...
Essentially, the query can reference the source features to see floor levels and you can limit which floor to locate on.
Best,
Robert
JaySandhu
Create a 3D point feature class and set the Z value to the floor value they need to snap to. Network Analyst supports network datasets with true 3D. You can also look at the indoor routing tutorial that comes with the software. Details here:
http://resources.arcgis.com/en/help/main/10.2/index.html#/Analysis_on_3D_network_datasets/0047000000...
Jay Sandhu
RobertGarrity
Hi Tobias,
Best,
Robert
TobiasLitherland1
Thanks guys!
I'll go for the Query Builder-option until I have obtained better Z-data. The network services I'm publishing use only one floor at a time, but with the query builder i can publish all the servies while only referencing one network dataset, which is a lot more robust.
Have a nice day!
Tobias
