OD Cost Matrix - Routes
2467
10-19-2012 11:54 AM
ArthurVrechi
Hello All,
I created a OD Cost Matrix using some origins and one destination, and it's working well.
I would like to know if is possible to show the routes between the origins and the destination, instead of showing just a straight line.
Thanks!
Arthur Vrechi
JaySandhu
OD Cost Matrix by design does not return back the route geometry for performance reasons. You can use the Closest Facility solver for that purpose. Load your Origins as Incidents and Destinations as Facilitiies and then change the number of facilities to find from the default 1 to the number of destinations you have and solve. it will compute all the routes and return back the route geomtries as well.
Jay Sandhu
ArthurVrechi
Thanks Jay!
It worked! I use it with more than 600 points and runs fast.
Arthur Vrechi
