not enough memory to create requested bitmap
3866
07-08-2014 07:32 AM
OscarCastaneda
I have a map created in ArcMap.
I open Network Analyst.
After I used Network Analyst for a while, I want to print the map that I now have
I get a "not enough memory to create requested bitmap" message.
If I save all the layers and open the map again, with Network Analyst turned off, everything works fine
Did any have this problem before?
I am using v 10.1
TimothyHales
Esri Notable Contributor
I've moved your post into the Network Analyst space. You will get a much better answer here as the GeoNet Help is intended for community help and feedback. You can see more on the community structure, and what topics are under each space from the following documents:
GeoNet Community Structure
ArcGIS Discussion Forums Migration Strategy
Thanks!
Timothy
