Network Analyst Routing: Failure while working with internal OD cost matrix problem instance.
1843
08-12-2019 12:38 PM
Sarah_Girdwood
I am trying to run a vehicle routing problem using model builder and I get the error: failure while working with internal OD cost matrix problem instance.
  • I have solved a vehicle routing problem using the same orders, depots, routes and routable layer before (in the network analyst window)
  • I have deselected all restrictions
  • I have checked "ígnore all invalid locations''
  • there are +4000 orders and 250 depots
I initially had memory issues but have rectified this.
Does anyone have any ideas of what I could do to solve this problem?
Thanks #vehicleroutingproblem #networkanalyst #routablelayer
Sarah_Girdwood
Problem solved - incorrectly copied network dataset was the cause.
Sarah_Girdwood
dbzedlerfire
@Sarah_Girdwood Could you elaborate on how you solved this?  I am getting this error when doing a vehicle routing problem.
