NetWork analysis--Route Part  Hope your generous help ! Thanks
1189
04-06-2010 08:27 AM
LisaChen
I would like to build a network analysis about metro for exercise.  And I vector the metro map while capturing the vertex. And Then I build the topology to test whether the data is ok with the rule: do not have dangles. All of these above is OK . So I build the network analysis with the field metroline length and metro lineid(1,2,3:Line 1,Line2,Line3) as two different cost. And Finally, I can find the route between Graphics 1 and Graphics 2 after I clicked the solve. However the problem come I use it in ArcGIS Server. It said that : GPMessage: It has no edges. Why??? I can find the route in ArcGIs Desktop and I'm sure that there is a layer which owns edges. Why???
I know it must have some detrmental error in my builing the network. But where and what should I do?
Hope your generous Help!!!
Thanks in advance.
LisaChen
Thanks god . The problem solved. It is nothing to do with the data . It's about the code. I set two points with the same coordinates value.
