Hierarchy Problem - No Solution Found
3070
10
11-14-2012 02:34 PM
RizwanShahid
When I have Hierarchy option enabled, I get an error "No Solution Found". Without Hierarchy, it works fine. There are 6 road classes, Hierarchy worked fine when I had Road Class 1-2 combined as Primary Highway, Road Classes 3-4 combined as Secondary Highway, and 5-6 as Local. When I changed Primary Highway from 1-2 to 1-3, rebuilt the dataset and ran the solution, I got an error. Any idea why is it happening?
Thanks in Advance.
R.
RizwanShahid
Thanks Jay. It worked. Now the problem is to set up turn delays based on the original hierarchy values. I had 1 to 6 hierarchical values; I combined 1 to 4 as Primary Road, 5 as Secondary, and 6 as Local. Now I want to include turn delays based on original hierarchical values (1 to 6). Different delays from 1 to 2 left or right turn and different turn delay from 3 to 4 etc. Any suggestion how to efficiently do it?
